Need help removing a 95 steering wheel
I tried removing the steering wheel with two types of pullers but none of them worked. Is there any other way to remove it without removing the steering column?
Which pullers did you try, and why didn't they work. That is the correct way to do it. I guess you could try MacGyvering something out of nuts and bolts.
Maikelo (January 7th, 2020)
ok ... and why didn't the steering puller work?
Rednucleus (January 8th, 2020)
I'm here for the party
pretty sure ive had to put the nut back on the steering column shaft without the lock plate in position and smack the nut/shaft with a hammer while pulling up on the wheel. if you have the nut a few threads above the shaft you can strip the threads if you mess up the threads a little you can fix them when you remove the nut.
