Need help removing a 95 steering wheel
Old Jan 6, 2020 | 11:57 PM
AntonioM2's Avatar
Default Need help removing a 95 steering wheel
I tried removing the steering wheel with two types of pullers but none of them worked. Is there any other way to remove it without removing the steering column?
Old Jan 7, 2020 | 2:05 AM
Which pullers did you try, and why didn't they work. That is the correct way to do it. I guess you could try MacGyvering something out of nuts and bolts.
Old Jan 7, 2020 | 9:05 AM
Irish_alley's Avatar
I'm here for the party
i remember making one for my 89 years ago. wasnt too hard but a typical "T" shape one will work just fine.
Old Jan 7, 2020 | 6:38 PM
AntonioM2's Avatar
I tried the 3 claw puller and the normal steering wheel puller but none of them worked
Old Jan 7, 2020 | 9:32 PM
ok ... and why didn't the steering puller work?
Old Jan 8, 2020 | 12:25 AM
you removed the nut right.....
Old Jan 8, 2020 | 3:30 PM
AntonioM2's Avatar
Not sure and yes I removed the nut
Old Jan 9, 2020 | 10:25 PM
pretty sure ive had to put the nut back on the steering column shaft without the lock plate in position and smack the nut/shaft with a hammer while pulling up on the wheel. if you have the nut a few threads above the shaft you can strip the threads if you mess up the threads a little you can fix them when you remove the nut.
Old Jan 10, 2020 | 4:57 PM
Little Bear's Avatar
Yes typically using a puller like that I usually find a couple of sharp blows to the tension bolt on the puller can help pop the wheel off. Being a tapered splined shaft it doesn't take but a touch of rust to really bind things up.
69impalaconvharv
Sep 11, 2018 5:53 AM
Surfurban
Aug 11, 2017 10:22 AM
bschnacker
Apr 3, 2011 10:46 PM
mommykatt
Jan 23, 2009 3:18 PM
swak
Jan 1, 2008 9:15 AM
