Need help scratching my head code 42&43
Old Jul 29, 2025 | 9:57 PM
Tonyk2500's Avatar
Default Need help scratching my head code 42&43
So here's my issue hopefully someone can help me with im getting codes 42&43 it runs perfectly at cold temps but once it warms up and I get it to highway speeds my rpm gadge will jump all around and 5 seconds later I'll hear a pop from the intake and it will loose power looks like my gadge cluster will shut off then I'll let off the gas and it will all come back no issues at all going up to 40 need help figuring this out
Old Jul 29, 2025 | 10:45 PM
Rednucleus's Avatar
Please post the vehicle details for better help!
Old Jul 29, 2025 | 11:49 PM
Tonyk2500's Avatar
It's a 91 chevy k2500 305 4x4 efi
Old Jul 31, 2025 | 4:02 PM
jfmorris's Avatar
All I can offer up is the definition of ODB 1 codes 42 and 43, from my Haynes manual:
42 - Ignition Control Circuit (shorted circuit):
Check the wiring and connectors between the ignition module and the PCM. Check the ignition module. Replace the PCM.
43 - Electronic Spark Control (ESC) system
ESC module is not receiving a knock signal from the knock sensor. Check the knock sensor or the ESC module. Have the module checked by a dealer service department.
IKnowNothing
Blazer
Jul 20, 2024 6:23 AM
bsihota
2007 - 2013 (GMT900)
Jan 10, 2024 4:50 PM
Russ74
Camaro
Mar 4, 2018 12:15 PM
roustabout
Sep 29, 2013 3:06 PM
craazyfool
Mar 1, 2010 10:21 PM
