New AC Compressor Missing Wiring Harness? Ur Eyes Please.
1997 Silverado 1500 RWD 5.7. Got a new wife. She came with an old truck (which she bought new). Was informed I will be treated well if I keep it running. So ... have updated and replaced several parts/systems. Now working on the AC system. Installing a new compressor and dryer. Pulled the old compressor. Compared it to new compressor. Exact match, except the wiring harness on the back end is missing from the new compressor. In fact, I cannot find any examples of a replacement/new compressor with that back side wiring harness. See images below. Anybody know what it is? Suggestions on what to do about it? I'm guessing its a temperature sensor. Obviously I took the snap rings off both in an effort to switch them out. Plug on new one popped off. Old one with harness crushed in the attempt, unwilling to budge.
Figured it out. That's where the pressure switch goes. You have to purchase separately. Odd no one mentions that.
HOWEVER ... I just closed everything up and attempted to charge the system. Got about a half a can in (out of 3 - total 36oz). Low Side pressure readings are way too high (68psi). Air coming into cabin is cool, not cold. I completely evacuated the system and let it sit overnight. No pressure leaks. So ... either I got the wrong pressure switch or somewhere the system is clogged. Open to suggestions.
Issue seems to be with the Orifice Tube. Wife hit a deer some months ago. Passenger side front bumper. I replaced the grill and lights. The line the Orifice Tube sits right next to/behind the turn signals. It must have been smashed just slightly out of round. Orifice Tube won't seat. Bummer is that line is integral to the entire A/C Condenser, so now that needs to be replaced too. This repair just got more expensive.
oilcanhenry (June 28th, 2022)
How to boost the longevity of the radiator
Taking good care of the vehicle’s cooling system will improve its efficiency and overall well-being. The car runs on gas & power gets converted into heat which further changes into the air via the radiator. Poor radiator maintenance would reduce its shelf life and lead to costly repairs in the future. However, you can take steps to stretch its shelf life by several years highlighted by the experts at reputed car parts and accessories stores online.
Read More: https://www.theautopartsshop.com/blo...f-the-radiator
Jeffrey Ellis
2014 - 2018 (GMT-K2)
May 28th, 2021 10:19 PM
dspud2006
10
July 14th, 2012 2:06 PM
Tom Cullen
July 21st, 2011 12:20 PM
