P0430 code
Old May 6, 2020 | 7:57 PM
Mr. Dude with a face's Avatar
Post P0430 code
I recently had a Service Engine Soon come on my dash. I decided that now was a good time to buy a, what I consider mid level scan tool. I probably am not using it to its full capability, but that is beside the point. About 2-3 weeks ago (100 is miles) I used the scanner to simply clear the code, 2 P0430 codes. The light went out, and stayed out for a long time, until today. I will include the fact that, when I look at the freeze frame data, it shows that my truck was fully warmed up, and at idle, not moving. I would like to know y'alls opinion on what it could be, is it a bad CAT, possibly a bad sensor. I also want to add that it does not appear to be consuming any notable about of oil or coolant, it might consume 3/4 of a quart between oil changes. My typical driving habits over the past 3000ish miles I have put on the truck (currently has 183K) includes mostly cite driving with the occasionally freeway trip. Thanks for any advice you may have, I would like to avoid taking it to a shop, but being a novice, I do realize their is a point that you give in, and take her the pros. Thanks everybody.
P.S. First Thread.
Last edited by Mr. Dude with a face; May 6, 2020 at 10:08 PM. Reason: no one is seeing my post i think
Old May 7, 2020 | 4:22 PM
New development. I did some looking underneath the truck and their is a gasket after the second CAT that is used to seal both exhaust pipes. I noticed that at that joint, their was a lot of dark, hard, black build up, that looked like it had been getting wet. I fired up the truck, and climbed back under and could see water dripping out of the joint, and when I put my hand up near it, I could fell the puffs of exhaust. I haven't replaced the gasket yet, so I can't be sure that it is the problem, but judging by the fact their is an O2 sensor immediately after the joint I feel confident that replacing the gasket will fix the problem. I will make another post in a few days to tell y'all if it worked. Hopefully it ends up helping someone else too.
Old May 7, 2020 | 4:49 PM
kevinkpk's Avatar
Like the 61(?) in your avatar.
Old May 7, 2020 | 7:33 PM
Thank you! Sadly it is not my truck, but it is my favorite year the 1960 to 1961 with the hood that is styled like that, once I have the space to park one I will get one. I really like the style of the hood, but I guess the market didn't in 1960 because I don't see many of them at all.
Old May 7, 2020 | 7:35 PM
@kevinkpk
Also, what is the car in your avatar picture? I have seen you post on some other threads and haven't been able to figure out what it is.
Old May 8, 2020 | 2:03 PM
kevinkpk's Avatar
Originally Posted by Mr. Dude with a face
@kevinkpk
1970 Olds Delta 88
Old May 8, 2020 | 2:06 PM
@kevinpk
nice
Mehthiro
May 20, 2020 3:14 PM
turbojimmy
Avalanche
10
Nov 22, 2017 8:51 AM
malibuboo
Aug 22, 2015 10:25 AM
firemechanic
Jul 7, 2012 8:48 PM
MC
Aug 24, 2007 10:27 PM
