Runs great, but timing will not set
Old Mar 5, 2018 | 2:54 PM
klayton_k1500's Avatar
Default Runs great, but timing will not set
I am getting p1345 code for crank/cam correlation.i did not have this code prior to replacing the distributor...now the timing is -20 can retard with old and new distributor. Took the truck to 2 different mechanics to have timing set and they can’t get it lower than -20.
Any ideas on what else could cause this issue?
The truck starts and runs great!
Old Mar 5, 2018 | 4:16 PM
kevinkpk's Avatar
Is it maxed out as far as won't go any further? Pull the distributor, and rotate it one gear. That will give you a little more base movement
Old Mar 5, 2018 | 6:20 PM
I have tried that, multiple teeth in both directions ... I’m wondering if the code means something other than timing
Old Mar 5, 2018 | 8:07 PM
kevinkpk's Avatar
https://www.engine-codes.com/p1345_chevrolet.html Try this
Old Mar 12, 2018 | 6:38 PM
-20 cam retard, what damage will it cause?
Old Mar 20, 2018 | 7:37 PM
The Crow's Avatar
I read some where that when the distributor is removed it has to be re-calibrated usually at dealer don't remember what year that pertains to.
