Settle a debate concerning 350s
Old Dec 14, 2019 | 9:07 AM
tank1949's Avatar
Default Settle a debate concerning 350s
I have a 95 Chevy Silverado with a 350 motor. Does all oil go through filter BEFOR lubricating any parts inside block, or is there some device or channel to take some oil to block parts (bypassing filter) before motor warms up? My concerns are about getting any NPT sealant (tape or liquid) plugging up oil journals. If all oil if filtered, I should not have any concerns. I recently used liquid sealant on a new oil sending unit. I also used high-temp sealant tape on an oil filter attachment (before going into filter side). THX!
Old Dec 31, 2019 | 12:40 PM
Little Bear's Avatar
All is filtered, there is a bypass but it only comes into effect if the filter is clogged.
Old Dec 31, 2019 | 2:20 PM
kevinkpk's Avatar
Yes. The only bypass is in the filter if the inlet press is too high, as in a plugged filter, and that allows, although unfiltered oil, to continue to the engine.
Old Dec 31, 2019 | 2:24 PM
kevinkpk's Avatar
If you are concerned about contaminants plugging the oil filter, I'd advise to run the engine for a hundred miles or so, then replace the filter. Filters are cheap.
Steve111
Nov 9, 2017 5:08 PM
MTJack
Feb 24, 2017 8:22 AM
fishing nut
Nov 27, 2015 10:27 PM
Injector
Feb 11, 2013 12:21 PM
superparadox
Jul 15, 2006 6:37 AM
