Spongy brakes
I've had the truck for about 5 years and the brake pedal has always been spongy I've replaced master cylinder brake booster front rubber lines over the years its been purged everytime some thing has been replaced that has to do with the brakes, just replaced rear brake shoes brake cylinder yesterday because I had never serviced them and they needed a replacement also hoping that the brake pedal would feel tighter but it feels the same as always maybe a little less but it still spongy it's also a daily driver and never really had any problems with the brakes I would just like to fix it as Im slowly restoring the truck, Ive been wanting to replace the abs module with one out of a junkyard to see if there's any change but i wanted to ask first if anyone has any ideas. thanks in advance! Ivan
The better way to get air out of the system is with a pressure bleeder and a scan tool to open the valves to allow the air to exit out the bleeding point .May require all 4 wheels.
I wish I could use a scanner I have a obd 1 .. is it possible to still use the pressure bleeder?
Thank you i will mess with it this weekend I know when I tried it first I only did a few pumps a couple of times out of curiosity but like i said nothing came out, I'm going to try that again
Thanks for your reply did it actually work? I just replaced my rotors and brake pads not too long ago but when I changed them I didn't notice any improvements at all.. I might try that later on if I can't find a solution
Maybe check with the dealer regarding 93 brake recall repairs. I checked my maintenance log - in Aug 2001, safety campaign work included replacing brake master cylinder rod & a thicker pad on brake pedal. Did give it a firmer feel, though I did not perceive a problem before that. If the work was already done you should find a white sticker on the radiator shroud.
Mr. Dude with a face
1988 - 1998 (GMT400)
44
January 10th, 2022 7:11 PM
shortbed1990
July 21st, 2021 10:10 AM
