Stalling issue on 94 blazer 5.7 tbi
Old Jan 17, 2022 | 8:12 PM
Ladydeath01's Avatar
Default Stalling issue on 94 blazer 5.7 tbi
Hey y'all. So my blazer starts up but stalls out after a couple seconds. Been doing this for two years so it's been parked. Here's what's been done. Yes, the stupid way of guess work. Smdh.
new ECM, new TBI Carb and jets, new distributor, IAC, TPS,o2 sensor, fuel filter, coil, wires, cap rotor and ignition mod. Nothing has made a bit of difference. It's been timed tdc with ignition set disconnected. Ground wires okay. No vac leaks are seen or heard. Also, attempting to drive it sends to lack power and runs pretty rough and I have to keep pumping the gas pedal to gain speed but it doesn't gain much. Black smoke. It's always sounded and idled and ran real smooth before the stalling began. I'm ready to just set it ablaze and walk away! Anyone?
Old Jan 19, 2022 | 9:38 AM
Sabino56's Avatar
Perhaps Check fuel pressure. How to in FAQs here somewhere.
Old Jan 19, 2022 | 10:01 AM
Rednucleus's Avatar
How old is the gas in the tank?
When you start it, you say it dies in a couple seconds; see if you can keep it running by carefully pouring gas in the throttle body. If it helps it suggests a fuel problem vs something else.
royposey96
Blazer
Aug 28, 2021 1:19 PM
Cal Blazer
K5 Blazer
May 29, 2021 3:16 AM
Bigbuddha
Sep 8, 2017 10:36 PM
racerdad2
1988 - 1998 (GMT400)
Jul 19, 2016 8:43 PM
JLBailey93
Apr 22, 2011 9:41 PM
