Starter Wiring Issues 89 Silverado
Old May 29, 2021 | 10:59 AM
SouthernChevy74's Avatar
Default Starter Wiring Issues 89 Silverado
So my starter wire burnt into, & the other wire that runs with it in the harness is a knock sensor wire I've found out. So I'm curious as to if anymore wires should be in that harness bundle & how hard it is to rewire a new knock sensor. I just buy a connector & wire it into the harness, correct?
The green/burntBlue wire is the knock sensor wire, correct?
Last edited by SouthernChevy74; May 29, 2021 at 7:23 PM. Reason: Knock Sensor Rewiring
Old May 29, 2021 | 8:53 PM
Gumby22's Avatar
Yes that’s the knock sensor wire - the starter solenoid wire is purple.
The only other wires that would be in the bundle are the wires for the front axle actuator, if it’s equipped with 4WD.
L84sky
Apr 11, 2023 11:38 AM
scott5134
Apr 28, 2019 11:37 AM
Chad Reynolds
1988 - 1998 (GMT400)
Feb 14, 2016 12:11 PM
Yoga Chou
Sep 12, 2015 12:46 AM
bavant
Jan 16, 2012 2:12 PM
