transmission oil line
Old Jun 22, 2019 | 8:38 PM
  #11
burnhedge's Avatar
It might be worth removing the cross member and letting the trans come down a few inches if you have a transmission jack.
Old Jun 22, 2019 | 9:07 PM
  #12
KChevy75's Avatar
You may also want to look into a 13 mm brake line socket. it should fit around the transmission line and allow you to get much more force on it to remove the nut. they also make an offset socket that will fit around a line like that that might work a little better than the brake line socket.
Old Jun 22, 2019 | 11:03 PM
  #13
Burtle's Avatar
I bought a set of brake line sockets. I still couldn't get a good angle on it. I cut the line to get it off. After I cut the big section out of the way I put a 13mm deep well and it came right off. I believe if I drop the exhaust and take a shield off the transmission next to those lines I can get it back on easier. It has been a pain!
I think I know what happened. I put a new engine in the truck three weeks ago and when putting the new engine in I hit that line pretty good. I'm sure that's what caused this issue.
I appreciate everyones help !!!!
