Very Loud high pitched whistle noise.
Old Jan 28, 2020 | 10:32 AM
davidt443's Avatar
Default Very Loud high pitched whistle noise.
2000 K3500 with the 7.4L vortec engine. Recently when starting the truck I would get a very high pitch whistle noise off and on only for a few seconds when cold out. I've noticed this noise only comes when it is cold outside, less than 60 degrees. Above that temperature it doesn't make any whistling noise. When it does make the noise it is so loud it is hard to pinpoint where it is coming from, and after about 3 minutes it will go away and wont come back until the engine is fully cold and started back up. Anyone experience this?
Old Jan 28, 2020 | 1:01 PM
Rednucleus's Avatar
Does the pitch change when you rev the motor? Belt squeal??
Old Jan 28, 2020 | 1:27 PM
davidt443's Avatar
It does not. I am thinking it is an Idler pulley and will change that out today. Hoping its not alternator or AC compressor bearings. Will put in a new serpentine belt as well.
Old Jan 28, 2020 | 4:23 PM
Rednucleus's Avatar
You can use a piece of heater hose as a stethoscope & carefully place it on each component (pulley, a/c, alternator) to find where the sound is loudest. CAREFUL with hose around moving belts & pulleys!!
Old Jan 29, 2020 | 8:55 AM
davidt443's Avatar
Confirmed Idler pulley bearing was bad. $25 later and a new serpentine belt the old 7.4L purrs like a kitten with no noises.
rervf23
Aug 14, 2011 11:30 AM
Tim1981
May 29, 2011 10:40 PM
TRProffitt
Jan 10, 2009 9:16 PM
mandyc
Jan 3, 2008 8:56 AM
sarahsimpson
Jan 25, 2007 2:59 PM
