Volt Meter Reading High
Old Jan 2, 2022 | 4:26 PM
Doc Hicks's Avatar
Default Volt Meter Reading High
Hey All - as you can see by the picture, my volt meter is showing that I'm running 16-18 volts. This is not new, it has been this way for quite a long time. It appears to work, because it dips when I have the turn signal engaged - and dips deeply when I'm operating the snow plow.
Is it possible that this gauge is just wonky. Or do I have an alternator that's trying to kill my truck?
Any thoughts?
Old Jan 2, 2022 | 5:30 PM
kevinkpk's Avatar
[QUOTE=Doc Hicks;474427]Hey All - as you can see by the picture, my volt meter is showing that I'm running 16-18 volts. This is not new, it has been this way for quite a long time. It appears to work, because it dips when I have the turn signal engaged - and dips deeply when I'm operating the snow plow.
Any thoughts?
I'd check it with a volt meter.
Old Jan 3, 2022 | 4:01 PM
Stockdale Dave's Avatar
Most auto parts stores have a mobile unit that will test the alternator, battery, and starter on the vehicle. It will tell if the voltage regulator has gone south.
2001expressowner84
Jul 30, 2021 4:22 AM
Bigbill1957
Sep 22, 2017 12:56 PM
79lincoln
Jan 25, 2016 11:15 AM
curtis1512
Nov 12, 2015 8:28 PM
Mikex2004
Nov 12, 2013 9:17 PM
