Voltage drop
Old Mar 24, 2023 | 10:07 PM
  #11
Gumby22's Avatar
Originally Posted by I.V. Tomlinson
Finally found the problem, the issue is the volt meter. With high beams on the volt meter will fall to 12V and lower, Meter reading at the battery is 13.6-14V.
I will install a second volt meter directly from the battery. I also notice when the high beams are switched the oil pressure and gas gauge flicker.
Good to know you figured it out.
If the oil PSI and fuel gauge are “flickering” with the high beams, a couple of possibilities come to mind:
1) There’s an issue with the headlights circuitry causing excessive current draw or back-feeding of some sort. Could be a faulty switch or relay, bad ground, weak connection or other wiring problems.
2) There’s other issues with the cluster, and in my experience with these trucks, that’s the most likely case.
Either scenario is going to require further diagnosis to confirm.
Old Mar 24, 2023 | 11:16 PM
  #12
I.V. Tomlinson's Avatar
Thanks for the info, I am changing the switch, and will look for a bad ground.
Grant Horsey
1988 - 1998 (GMT400)
Sep 1, 2017 8:43 AM
sadegs
May 11, 2017 2:21 PM
RakJimmy
Mar 7, 2017 5:16 PM
Eaglewwit
Nov 23, 2015 6:57 PM
99SuburbanTX
Sep 13, 2012 9:34 AM
