Where do these two electrical connectors plug into?
Old Nov 13, 2019 | 5:40 PM
  #11
stylingpat's Avatar
Yeah I cant figure out how to remove these terminals. This is driving me nuts.
Old Nov 13, 2019 | 8:00 PM
  #12
Originally Posted by stylingpat
Yup that would fall under high contact resistance
What would?
My connection 30 is melted a little ... could the contact point not be tight enough and its causing the electricity to arc inside and heat this sucker up?
If the socket is a bit loose or corroded, that would increase the electrical resistance, which increases the amount of power dissipated in it (AKA heat). It would not even need to arc. (Not that 6A would arc much anyway.) Just poor contact is enough to cause a connector to heat up.
Does your fusebox have a cover? Sometimes people loose it, and then everything inside starts to corrode. Or maybe it got wet. Might be worth taking it apart to assess its condition.
Old Nov 13, 2019 | 8:03 PM
  #13
As far as I know, you can't remove those terminals. They are part of the circuit board.
Old Nov 14, 2019 | 6:23 AM
  #14
stylingpat's Avatar
They look like they can be removed. They are just wires with a female connector on the end, pushed into the box and "locked" into place. I can still wiggle them forward and back but cant withdraw them out. There is no circuit board. And the empty spots all have these "tabs" on them that push away like I labeled in the photo. Seems no one on the internet knows how to remove these.
Old Nov 16, 2019 | 11:27 AM
  #15
stylingpat's Avatar
Alright no one on the internet knows how to remove these terminals, but now I do LOL
That "plastic bar" that I wrote about in the green text in the picture. If you go on the "BACKSIDE" of the relay box which is the side that is closest to the steering wheel. You can pull that "plastic bar" outwards. Its like a tray of bars that slide under the relay box. So the terminals are being held in place 1st by the tab they click into, then 2nd you slide the bar back under them. So that's how they come in and out.
Fixed up my burnt wire, and re bent the terminal ends for a clean connection.
Switched out my Oil Pressure Sensor
Plugged everything back together and my 375k all original c1500 is driving like she always has, a champ.
I noticed the new relay still gets "warm" but its not like how it was before. Before it was scorching hot instantly. So I got a few extra relays, I'm going to drive her until she breaks, and then if its the relay melting. I have a new complete relay connector/and relay unit, that I'll going to cut the fuel relay wires and just wire in a whole new connector and unit and go from there. But yeah. Trucks running good. Hopefully this is it for my "fuel gremlin" that has popped up back and forth these past few years.
Old Nov 16, 2019 | 12:16 PM
  #16
Thumbs up
nice work, and thank you for following up.
brerobx
14
Jun 26, 2021 4:36 PM
hcgonzalez
S10 & Blazer DIY and Useful Threads
Jun 22, 2019 9:55 AM
bvectra
Jun 29, 2016 4:36 PM
elsworth
Sep 13, 2010 11:30 PM
YEE HAW
May 10, 2010 7:03 AM
