Window issues
Old Oct 15, 2020 | 2:48 PM
scott64079's Avatar
Default Window issues
Daughter wrecked my truck. Replaced driver side door. Originally electric window and lock. Replacement is manual. Now passenger window doesn't work. Was power fed from drivers door? If so how do I get power to that door so window will work?
Old Oct 15, 2020 | 5:24 PM
Maikelo's Avatar
Please always tell which truck, year, type, engine etc. you got makes it easier for people to help
But to help you answer your question: Did you check for a blown fuse? And google for a power window electrical diagram so you can find out if they are linked.
Old Oct 15, 2020 | 6:28 PM
kevinkpk's Avatar
The drivers side door window switch had the power to the passenger door window, it will have to be bypassed at the driver side "switch" as that no longer exist.
Old Oct 16, 2020 | 7:40 AM
scott64079's Avatar
I've googled several diagrams and have come up with several diagrams that have nothing but lines no color coding, component list or key. Would you have any idea what wires/need by passed or a good diagram?
Old Oct 16, 2020 | 9:42 AM
kevinkpk's Avatar
I'd suggest pull the switch, and check for battery voltage, probably the battery voltage came from the driver side.
Old Oct 16, 2020 | 10:11 AM
scott64079's Avatar
1990 1500 Silverado
1/2 ton
350cci
2wheel drive.
Old Oct 16, 2020 | 11:08 AM
If it were me, I would convert the new door with manual window and door lock to electric. I would use as many of the parts I could salvage from the damaged door and get the rest from the junk yards or buy new if I had to.
Old Oct 17, 2020 | 7:30 AM
scott64079's Avatar
Not viable. Took 9 months to get a different door. Just need passenger window to work.
Old Oct 17, 2020 | 9:37 AM
Rednucleus's Avatar
if the original door harness is ok, plug the old switch in and hide it somewhere else so the passenger side will work
Blue Yonder
Aug 3, 2018 12:31 AM
Photon440
Sep 11, 2017 1:07 AM
gates62
May 10, 2010 3:57 PM
pose_master
May 2, 2010 1:23 AM
Blurple Suburban
Sep 2, 2009 3:03 PM
