1999 silverado extended section drivers side
Old Aug 25, 2019 | 12:05 PM
rbig1's Avatar
Default 1999 silverado extended section drivers side
Well cutting out rusted area. Inside the outer panel behind drivers section. There is a yellow foam seal glued to inner panel. What do you use to replace, mine is had. I do not know what its called or what its actually made of. Cant find it in LMC and the likes to buy a new one. Any ideas????
Old Aug 25, 2019 | 10:44 PM
oilcanhenry's Avatar
I'd try Home Depot for a foam sealer. Seriously.
Old Aug 28, 2019 | 7:53 PM
rbig1's Avatar
well went to chevy dealer. The body shop leader said to leave it out as that is one of the rust out causes. I fiber-glassed the inside parts after putting on rust killer. This man has been the leader for as long as I remember. Its to late to change my mind now. welded it in last night. Thanks for the reply.
Old Aug 29, 2019 | 6:52 AM
Gald you found a solution to your issue!
Stef
Aug 28, 2014 9:48 AM
friesner_28
Jul 27, 2013 12:44 PM
mx519
Jun 21, 2012 10:28 PM
skippybriggs
Apr 29, 2011 11:43 AM
tiptoa
Feb 14, 2011 12:20 AM
