2000 1500 Power Window
Old Jun 3, 2020 | 12:48 PM
shelb1500's Avatar
Question 2000 1500 Power Window
Hey Yall,
I have a 2000 Silverado 1500 woods truck.
My driver side window does not go down. And quite frankly I'm tired of opening my door at drive-thru’s.
I have replaced the fuze to start. Then I replaced the entire motor with the harness assembly and the power window switch but still got nothing (the passenger window is on the same switch and works perfectly). I have a circuit tester and I am able to control the passenger window though the harness. On the driver side when I try to do the same thing, I can hear the power in the motor to go up but has no power whatsoever when I try to put it down.
I do the work on my truck myself and I am still learning but my only assumption is that the wire that powers the driver side directly, is what needs to be replaced. Problem being, I am not positive that is exactly what needs to be fixed, and I would not like to pay someone $175 hr just to tell me that. Or if that is it, I am not sure how to replace it. So if anyone has an idea or knows how to help, please do.
Thank you!
Old Jun 3, 2020 | 10:41 PM
Irish_alley's Avatar
I'm here for the party
i know some trucks the passengers side gets power from the drivers side. so if your passengers side has power the drivers side will also. that being said im not sure how yours is wired. can you put a test light on the wire harness from the switch to the motor and see if its sending power?
Old Jun 4, 2020 | 1:56 AM
oilcanhenry's Avatar
Probably a cracked or corroded wire in the wiring loom, if its not the 50 amp fuse.
shelb1500
Silverado DIY and Useful Threads
Jun 3, 2020 5:22 PM
Betaform
Jun 14, 2016 11:32 PM
heavymetl420
Astro
Oct 8, 2009 10:48 AM
rat55chevy
Apr 26, 2007 6:50 PM
