2000 Chevy Silverado 4.8
Old Aug 8, 2023 | 9:57 AM
Daveys69's Avatar
Default 2000 Chevy Silverado 4.8
So my Silverado idles fine but everytime I shift from any gear back to park my idle goes up and sets a high idle code???? Any ideas on why this happens
Old Aug 8, 2023 | 8:26 PM
2001 chevy silverado's Avatar
idk. but your engine is connected to your trans by connectors (if you have oily connectors...). check both engine and trans codes (does your OBDII do trans?). Check battery and grounds first for any repair, as always. (this is all without your saying what you have haven't tried yet)
Make sure you do justice to your trans fluid level (checking right way, draining if jiffylube overfilled it) before diagnosing.
* mass airflow sensor - do you have an acorn stuck in it
* make sure there's no load when idling in N,P,D (does your car move when you take foot off brake with no gas, and have proper force)
* if you actuate the throttle by hand do you notice anything? is the linkage there ok?
* if you spray around intake gasket does idle change? (is there an intake leak?)
Old Oct 31, 2023 | 10:38 AM
Daveys69's Avatar
I’ve done all of which you mentioned and yes my code reader does all and the only code is higher than expected idle!! 🤷‍♂️🤷‍♂️.
Daveys69
Dec 13, 2022 9:11 PM
roaddawg15@gmail.com
Feb 19, 2022 3:26 AM
Bigbat72
Aug 25, 2021 6:55 PM
newtochevy
Jan 29, 2015 8:24 AM
gonmoises
Sep 20, 2011 1:46 PM
