2000 Silverado 1500 not starting
Old Nov 17, 2020 | 10:23 PM
Trichiro's Avatar
Default 2000 Silverado 1500 not starting
Truck was broken in to. Both door lock cylinders were knocked inside door. Ignition cylinder was damaged with a screwdriver, bad enough that a key won’t work anymore. Burglar removed the ignition switch by releasing the two pins. Theft mission failed. When I got to the truck it tried to start engine by manually turning the ignition switch to start. Engine turned over but won’t start/run. It’s almost like a kill switch has been activated. Any advice on how to get it running is appreciated. Thank you.
kevinkpk
Apr 16, 2018 5:14 PM
AZSTATE
Oct 26, 2016 7:47 AM
LeBish
Aug 7, 2013 10:25 PM
Maytag1
Jan 7, 2011 11:24 PM
Stoepified
Apr 1, 2008 11:32 PM
