2002/2004 Silverado 5.3 won't start
Old Mar 27, 2024 | 1:52 PM
Chad96's Avatar
Default 2002/2004 Silverado 5.3 won't start
I recently done a motor swap and my motor will turn over but won't start. I tried starting fluid and still didn't work. Been told I got the wrong wiring harness since it came off a 2002 suburban flex fuel. My setup is drive by cable since the truck is set up for it already.
Old Mar 27, 2024 | 3:13 PM
chem_man's Avatar
15 Year Member
Which PCM are you using - the one from the existing vehicle or the one from the donor vehicle? Have you done the BCM to PCM relearning procedure for the vehicle security system? Do you hear the fuel pump running?
Old Mar 27, 2024 | 3:24 PM
Chad96's Avatar
I don't hear fuel pump running and I'm using computer from donor vehicle
Old Mar 27, 2024 | 11:08 PM
chem_man's Avatar
15 Year Member
OK on the no fuel pump noise.
Did you perform the BCM to PCM relearning routine? If not, then that could be your problem as the VINs stored in each control module are different and hence, the PCM is not allowing the fuel pump to engage. It is a security measure.
Try the 30 minute procedure detailed in the attached pdf file. Make sure your battery is fully charged!
Good Luck!
Old Mar 28, 2024 | 7:18 AM
Chad96's Avatar
I will try that. I completely forgot about this step.
Old Mar 28, 2024 | 3:05 PM
Chad96's Avatar
Good Luck!
It didn't work sadly
Old Mar 28, 2024 | 11:40 PM
chem_man's Avatar
15 Year Member
Sorry to hear that.
The next step I would do is to go over all the electrical connections and make sure that there are no bent pins inside the connectors, that the wires are secure going into the connectors, that you did not forget to reconnect any ground leads, etc.
Good Luck!
Old Mar 29, 2024 | 6:38 AM
Chad96's Avatar
Sorry to hear that.
Good Luck!
I've done this step multiple times already. With my vehicle not being flex fuel and the wiring harness I got came off flex fuel, could that be an issue?
Old Mar 29, 2024 | 4:00 PM
yeah, it's expecting an alcohol sensor signal
Old Mar 29, 2024 | 8:52 PM
Chad96's Avatar
Should I get that sensor off the donor vehicle?
