2004 2500hd w/t radio
Old May 22, 2023 | 12:10 PM
tuckerjesse74@gmail.com's Avatar
Default 2004 2500hd w/t radio
Okay so I am in need of some guidance here, I have an 04 Silverado 2500hd that’s as base as base gets, no power options at all and manual trans and transfer case, 6.0 gas but has cruise. P/o put a Sony radio in the truck what looks like years ago and now it’s faded and the buttons do not work, so I put a new boss unit in, used the pac interface for the chin that was already there and I have no sound, removed the interface still zero sound, changed head units still no sound, I can unplug that head unit, plug it into my 95 and have sound, but none in the 04 no matter what of the different 3 units still NO SOUND
please help lol I’m losing it
Old May 24, 2023 | 1:57 PM
chem_man's Avatar
15 Year Member
One cannot just install a radio in these vehicles like in the old days. What it looks like is that you will need a new interface harness that goes between the radio and the truck's internal computer/modules communication system. Without the "blessing" of the Body Control Module, the radio will not work right.
I suggest you go to crutchfield.com and see what is needed for the installation of your new radio. Crutchfield is THE expert for things like this.
Good Luck!
Old Jun 8, 2023 | 12:41 PM
Lespaul1978's Avatar
Good Luck!
I just installed one in my 2005 silverado, I had to run a separate ignition rather then the one in the truck wiring harness the red ignition wire in your truck will not have 12 volts on it , so i ran a fuse tap to the ignition side of the fuse box and it now has power to the new stereo.
I replaced the GM factory radio.
Hope this helps.
ajacksix0
Apr 2, 2021 12:20 PM
stargate_k
Jan 26, 2015 7:48 PM
Twobears
Dec 16, 2013 2:37 PM
mneal
Sonic (Aveo)
Apr 7, 2012 4:26 PM
vmxf
Oct 3, 2009 7:12 AM
