2004 chevy 1500 4x4 extended cab vibration
Old Jan 8, 2021 | 12:40 PM
jerryadams123's Avatar
Default 2004 chevy 1500 4x4 extended cab vibration
Hi new to this site, I have a 2004 chevy silverado 1500 4x4 extended cab that has a vibration at 55mph plus. I’ve replaced the rear driveshaft, rear axle seals and bearings and had the new driveshaft rebalanced at local driveline shop and still the vibration persists. Any help or knowledge would be appreciated.
Old Jan 9, 2021 | 5:24 AM
oilcanhenry's Avatar
Why did you not just have your original drive line rebalanced? Unless it was bent somehow, that's what I'd have done.
Old Jan 9, 2021 | 9:13 AM
original was bent
Old Jan 11, 2021 | 9:24 PM
original was bent
Good enough for me.!
Do you know why or how it was bent?
Old Jan 12, 2021 | 7:18 PM
Craig0320's Avatar
Sounds like you got some excess play in your ring and pinion. I had a ranger with a vibration around 40-46. Replaced the rear end and made everything smooth. I could really tell when I had it up on the lift. I could rotate the pinion almost an inch before the wheels would turn. The new rotates about a 1/4 or less and the wheels turn.
spidermonkey
Mar 28, 2015 6:24 AM
kc15
11
Mar 19, 2013 2:52 PM
allen7447
Dec 17, 2011 8:49 PM
transam1
Jun 11, 2010 9:47 PM
stsscott
Feb 28, 2009 8:03 AM
