2004 Chevy 2500hd 6.0L having problems!! Help!!
ok.. 2004 chevy silverado 2500hd 6.0L throwing codes.. dont remember what code numbers but it says its lean on bank 1 and bank 2. Guy at oreillys said mass air flow sensor... switched that out and didnt do any good.. The truck starts and idles fine but when accelerating it is really doggy and wont rev past 2500 rpms.. Does anybody know anything that can help me out on this???
Verify your air filter is clean. Don't worry about your gas filter, you haven't got one.(Boy, was I pissed when I found that out about MY '04- 2500HD-6.0.) Write down the trouble codes, and pay particular attention when you first start your truck. Your DIC may be trying to tell you something.
I've been lucky, haven't had a problem like this so far. Anybody else got any ideas?
yea after plugs and wires fuel filter was my next option and then i found that out also.. had a chevy mechanic scan it tonight and still saying lean on both banks and that the MAF Sensor is low frequency circuit or something. i switched the sensor with the one on another truck and the other truck runs fine with my sensor on it. And mine is still doin the same ol thing.. cleaned the air filter out not to long ago so it should be fine..
still looking for any opinions.. o2 sensors maybe? just hate to play quess and check with electrical parts since they are non returnable...
any help is much appreciated..
definately not an air filter.. took the filter completely out and its not any better. no offense but i live and work on a farm and i know how to take care of my vehicles and equipment. gettin the gasket kit tuesday and changing them either tuesday night or wednesday night.
While you're under the hood, check the fuse box over the driver side wheel well. I had some dagnab rodents(Dagnab!) living inside the cover. They even ripped fiberglass insulation off my firewall to insulate their nest! Maybe some little unwanted vehicular resident chewed thru a wire. They love our warm and friendly Vortec engines.
My FIL's a farmer, he keeps his 03 Silverado immaculate.
mechanic at the local chevrolet dealer still said intake gasket. i took it back apart and coated both sides of the gaskets with gasket maker and now im letting it cure and will drive it tomorrow and find out if it works or not..
