2004 Chevy Silverado no crank no start
Old Jan 29, 2024 | 8:44 PM
Clappedoutcateye's Avatar
Default 2004 Chevy Silverado no crank no start
So I was having no turn signal on the right side of my truck went and replaced the multifunction switch and the flasher relay with the updated one.
then when I turn the ignition on the check engine light doesn’t come on. I know it supposed to when ignition is on so I’m assuming it’s related. I was having an issue where my trunk would just crank over and over so I replaced the fuel pump after I verified it ran with starting fluid. Haven’t had any problems until I dug into the dash it seems. I noticed two disconnected green wires on of the multifunction switch plugs. Kinda tired of throwing the parts cannon and thanks for reading
Old Jan 29, 2024 | 9:26 PM
have you tried running a diagnostic scan?
Old Jan 29, 2024 | 9:34 PM
I hooked up my cheap scanner and it wouldn’t read anything since I reset it when I disconnected the battery. I do remember having a sporadic u1000
Old Jan 29, 2024 | 9:40 PM
looks like you have a whole bunch of electrical problems. You'll probably have to go back and check your work with a good set of schematics. You can find some on charm.li
Old Jan 29, 2024 | 9:43 PM
thanks I’ll look on there to see what I can learn. Yeah I’ve been having all those codes and it ran fine so I don’t worry too much ab it affecting it now . Trying to make this simple and cheap but electrical problems never are.
Aqualad
Oct 31, 2024 1:08 PM
acampbell0566
Uplander
Jul 20, 2018 7:21 PM
freshnclean
Mar 23, 2014 8:50 PM
vortec02
May 24, 2010 6:00 PM
bklyn48
May 15, 2008 3:55 PM
