2004 Silverado 1500
Old May 14, 2021 | 12:31 AM
Mamahoney's Avatar
Default 2004 Silverado 1500
Have replaced everything
starter, plugs & wires, fuel filter & pump, battery. After not starting 2 or 3 days won't start. Sounds like going to but when let off key sounds like its chugging start pumping on the gas while trying to start and it finally catches and starts. As long as you run it everyday it will start first turn.
Old May 14, 2021 | 12:54 AM
oilcanhenry's Avatar
Sounds to me like you need a new battery. Don't forget to check your alternator as well. Seen lots of new battery's made in Asia, that cant hold a charge.
Old May 14, 2021 | 1:14 AM
Mamahoney's Avatar
Have new battery
Old May 30, 2021 | 12:12 AM
rpeters549's Avatar
Do these have a fuel pressure regulator them? If so it might be allowing pressure to bleed off over time causing this. It happens with some Ford's.
Old May 30, 2021 | 6:02 PM
Yes. All F-I motors use a fuel pressure regulator. You might want to check that out.
artimious7
Dec 15, 2020 5:10 PM
Chubba
Sep 13, 2014 8:43 PM
Charlie101
Jan 19, 2014 7:21 PM
flmeyebrows
Jun 21, 2011 10:51 AM
97-SilveradoMan
14
Sep 11, 2010 12:39 AM
