2004 silverado ac issue
Old Aug 10, 2021 | 11:04 AM
southland361's Avatar
Default 2004 silverado ac issue
Got an issue with my ac. Works fine then every now and then it won’t cool. Relays and fuses are good. Ive pulled the fuse to reset the control unit. Worked one time. Yesterday it didn’t work. This morning turned on truck and checked fuses with my test light and had power and ac was working. Is my control unit going bad?
Old Aug 12, 2021 | 12:13 AM
when it won't cool....is the compressor clutch engaged or disengaged?
Old Aug 12, 2021 | 2:13 AM
its not engaged. Pass two days its been working fine.
Old Aug 12, 2021 | 7:35 AM
hanky's Avatar
I believe we have a problem here, Houston !
Don't like to interfere when someone is attempting to help, so tech2, all yours !
Old Aug 12, 2021 | 3:46 PM
2001 chevy silverado's Avatar
They tell you you'll be fined $10,000 if you let a peep of freon into the atmosphere - while selling expensive imports to help you do that.
They've built cars and home AC which 100% of the time release SEVERAL POUNDS AT A TIME into the atmosphere - almost always failing not by mechanical failure but: by holes and release failures.
How do you feel about your federal moguls and MFG? How do you feel about the threats against you on not releasing a peep?
And is there really science or lies behind it all? Is this a COVID scare or are they the ones who should get a good shake down?
Old Aug 12, 2021 | 3:51 PM
In General:
First make sure your AC compressor is running. It should not cycle frequently (would usually mean low on freon).
If AC is on, then check your HOT DOOR VENT / "mixer vent". If you have AC controls problems or a bad actuator you'll get hot air in your AC and you will think the AC is not working when it is.
If you can't pin down either of those: feel the lines with your fingers no high tech needed, while the AC runs. The liquid line should be warm to touch (not ambient, not super hot after it exits the condenser). The evaporator line should be colder than a sweating beer bottle (not 62 more like 42). If you feel kinda no temperature on both: you have almost no freon in the system or some other bad problem.
You said it "works sometimes". That's probably good news means you definitely don't have a feon leak. It's more likely your AC controls. Un-probable chance of an engine compartment AC solenoid wiring issue.
Since we asked about wiring and controls: step 1: make sure your battery is good, that's always first. step 2: check your grounds make sure engine grounds are attached and clean. either of these can cause really strange things to occur so you have to do those first.
Old Aug 12, 2021 | 6:18 PM
tag team...its all yours. Not sure where i'm going....what do you think?
Old Aug 22, 2021 | 1:18 AM
Originally Posted by 2001 chevy silverado
In General:
it’s stopped working again. I tryed resetting the ac control by pulling the fuse. Didn’t work. Next day got it and worked fine. Got new ac control panel. Going install. Think it should handle the problem since everything works.
Old Aug 22, 2021 | 6:35 AM
hanky's Avatar
I had a problem with the compressor clutch not being engaged and the A/C working fine.
skylar troutwine
Jul 18, 2021 10:15 AM
radar1234
Jun 26, 2018 1:55 AM
Attren
Feb 25, 2015 1:45 AM
wethebonds
Aug 14, 2014 3:31 PM
Greg Tidey
Jul 27, 2012 4:51 PM
