2004 Silverado z71 shift cable
So the clip on the transmission end of the shift cable finally broke. From what I can find there are 2 different cables (131 and 140). However they both list the same applications, is the only way to be able to tell is to pull the old one first? Or am I missing something?
Not sure on a source - theyre probably discontinued through GM, but at the very least a dealer could probably give you a part number to reference when searching.
That said, more than once Ive secured them with a heavy duty zip tie (1/4 wide and about 3/32 thick) without problems. Just route it through the wings like the original clip did - the head of the zip tie serves the same purpose as the original clip. It will at least get you by until you can find a replacement.
Yea, looks like that would be the only real option....right now I have the old one secured in place with a hose clamp, as the parts store only had the 131 in stock. Dont guess its possible to only replace the outer portion of the cable?
