4L60E needs to be install
Old Mar 25, 2021 | 9:54 PM
laloquera's Avatar
Default 4L60E needs to be install
I have not been in here in a great while. Need help with a sticky or a kick *** write up in dept detail with torque specs. 99 Silverado extended cab Z71
Thank you
Old Apr 11, 2021 | 11:44 AM
laloquera's Avatar
Anyone, Im in the miiddle installing it. Having the time of my life here. Thanks
Old Apr 11, 2021 | 5:33 PM
hanky's Avatar
If you use at least 2 guide studs , it makes install much easier and just make sure you cut a slot in the ends so they can be removed with a screwdriver.
Old Apr 11, 2021 | 10:43 PM
laloquera's Avatar
Actually, Im past that point.. Im having issues with the top bolt at the very top. I used a swivel with an long extension to get it off,, but the wierd angle on the passenger side of the tranny is my only shot to put back in. Shopping for a long 15mm wobbler socket tomorrow,. Anyone out there have any positive feed back or alternative method? Im all ears, thanks.
Old May 17, 2021 | 10:42 PM
laloquera's Avatar
This job is done with, nailed it.
Cateyeguy
Jan 27, 2017 11:10 AM
Bernard Benson
Nov 20, 2015 7:33 PM
Sweettmoss95
Sep 10, 2014 8:37 PM
gaftop1
Jun 16, 2012 9:27 PM
dragondad
Jan 1, 2007 3:27 AM
