4l60e slipping out of gear
So last month my transmission went out and i bought a used 4l60e. After installing i found i had no reverse and only 1 forward gear. After about 50 miles it started to slip out of gear. After it would slip out it would not go into another gear until i shut off the truck and let it sit a few minutes. After starting it back up or would go into gear and roll for about 5 seconds, then slip back out. You buy used you get used. So i stayed looking for another. Well last week i bought another tranny that i knew for a fact worked. Well it's doing the same exact thing the last one did, minus the gear problems. I unplugged the wiring and it still does it so it is not an electrical issue, as it should have gone into limp mode. The only thing i can think of is maybe my cooler is stopped up. Would a blockage cause the transmission to slip out of and not go back into gear?
