99 Silverado 5.3 385k misfire on cylinder 4
Old Mar 3, 2024 | 2:19 PM
sprttruk1999's Avatar
Default 99 Silverado 5.3 385k misfire on cylinder 4
I have a misfire on cylinder 4, 99 Silverado 5.3 385k, I have replaced fuel injectors, spark plugs, swapped coil packs with other cylinders, swapped plug wire, fuel pressure is about 58, compression test on cylinder is about 150. When running live data i only see misfires on idle, if under load driving misfires zero out. Any ideas where to go next
Old Mar 3, 2024 | 3:19 PM
could be a failed injector circuit. A good diagnostic tool can do an injector balance test.
https://troubleshootmyvehicle.com/gm...oid-light-test
or a leaky intake gasket
tng196664
Mar 9, 2015 8:09 AM
Truck Lovin Girl
Mar 31, 2014 8:35 PM
unkindshadow35
Feb 2, 2013 10:50 PM
a_kraker99
Nov 6, 2012 9:25 AM
TahoeMatt
11
Feb 6, 2012 7:15 PM
