99 Silverado Dash lights
Old Jan 9, 2020 | 11:34 PM
Dchenault's Avatar
Default 99 Silverado Dash lights
Keep getting a repeating error on the dash to check engine oil level and add coolant but both are completely full (to recommended amount) any ideas?
Old Jan 10, 2020 | 5:27 AM
oilcanhenry's Avatar
Id try disconnecting the battery, Are you getting any codes?
Old Jan 10, 2020 | 4:53 PM
Little Bear's Avatar
Both cases use a simple level switch to indicate low. I don't know off hand if the switches are normally open or closed in "full" position, Since the coolant switch is the easiest to get to pull the connector off and see if you get the low level indication, if you do then the switches are normally closed in the full position and would indicate that you have bad connections allowing for an open circuit and false indication of low levels.
Old Jan 10, 2020 | 9:22 PM
Dchenault's Avatar
I bought an obd reader and I was getting an O2 code but because the previous owner pretty much chopped the whole exhaust system out and another one for an MIL lamp or something of that nature. I’ll have to run it again to get the actual code though. Bought the OBD this morning then worked all day
Chevychevy23
May 5, 2014 8:33 AM
paintballhead03
May 14, 2013 9:08 PM
Wikun
Jan 23, 2013 12:20 AM
twstevens
Jan 19, 2013 1:34 AM
warrennw
Jan 25, 2012 3:20 PM
