ABS Wheel Speed Sensor
Old May 31, 2023 | 11:06 AM
Vttrees's Avatar
Default ABS Wheel Speed Sensor
First time user of forums.
I have a 2002 Chevy Silverado 2500HD with 83000 miles. The issue is the truck pulls to the right when braking. I also hear what seems to be a grinding noise when I depress the brake pedal at low speeds. I have had the front end aligned, and the brake system is in good working order. I changed out the ABS front left wheel speed sensor, but the vehicle still pulls to the right and the noise still exists.
I'm not getting any codes or indications of a problem. My question. does the abs sensor require a shim under the sensor. The unit I installed didn't come with one. And I didn't notice a shim with old sensor but there was a lot of rust that I scraped off.
Any assistance is greatly appreciated.
Old May 31, 2023 | 12:02 PM
Rednucleus's Avatar
Welcome - the sensor should not make your ride pull when braking, nor cause grinding noise when braking. I would look again at brake hardware - rotors, calipers, pads...
If it pulls right then the offending parts should be on the right side.
Old May 31, 2023 | 1:35 PM
Vttrees's Avatar
Default ABS wheel speed sensor
Thank you for your response. According to 1aauto.com a bad sensor would cause the vehicle to pull to one side. It's more of a pulsating in the pedal and not a grinding. I apologize for using the wrong term.I'll probably ask a mechanic at the nearest chevy dealership if a shim is required under the sensor.
Old May 31, 2023 | 2:37 PM
Rednucleus's Avatar
Thanks for clarifying - you should get some more responses from folks far smarter than me in the next day or two!!
Old May 31, 2023 | 8:28 PM
shim is not required. if you shim it you will cause the sensor signal to drop out a low speeds. signal drop out will cause a false abs activation.....the abs pump valves will dump pressure....the pedal will sink to the flow and the valve cycles will sound like a buzz noise and the pedal will vibrate.
if the sensor has rust build up on the hub....it creates drop out.
Old Jun 15, 2023 | 7:53 AM
Vttrees's Avatar
Thank you for responding to my post. I'm going to pull the sensor and clean the hub again. I may have missed some rust when I replaced the sensor, and as you stated it is probably causing the issue I'm having.
GMT800
Jul 22, 2021 3:50 PM
Reeseschevy
Apr 26, 2018 8:42 PM
Gooseslayer-1
Avalanche
Mar 12, 2017 10:34 AM
kystang90
Nov 30, 2010 9:15 PM
SilveRAWdo
Oct 28, 2010 4:59 PM
