Need help with extended front brake hoses
Old Jun 15, 2023 | 5:50 PM
Jogn's Avatar
Default Need help with extended front brake hoses
I installed a lift kit on my 2004 Sierra 1500, it’s an extended cab standard bed 2WD 4 disk brake truck. The front brake hoses are rubbing, I ordered extended lines but they are a circle connection at the banjo bolt and not a diagonal, they are also missing all the mounting brackets. Will they fit my truck, and if not, what could I order? I will put what my current lines look like, and the ones I purchased below. Thanks in advance!
Current lines: https://www.autozone.com/brakes-and-traction-control/brake-hose/p/duralast-brake-hose-71201/221045_0_0
Lines I purchased: https://spindle-source.com/1999-2007-chevy-silverado-gmc-sierra-1500-stainless-steel-extended-brake-lines/
Old Jun 17, 2023 | 2:53 PM
oilcanhenry's Avatar
Current lines: https://www.autozone.com/brakes-and-...201/221045_0_0
Lines I purchased: https://spindle-source.com/1999-2007...d-brake-lines/
At worst I suppose you could use some heavy duty tie-straps.
96 Junk That Moves
1988 - 1998 (GMT400)
Sep 3, 2022 4:35 PM
378DRIVER
Nov 17, 2016 8:10 PM
05RedZ71Sub
Dec 18, 2010 12:29 PM
pwinstead
Oct 28, 2008 10:14 PM
