Battery Change
Old Jun 29, 2020 | 7:04 PM
DoubleDee's Avatar
Default Battery Change
2003 Silverado - I just found out about re-calibrating the ambient atmo temp. sensor after changing the battery (which fix my problem). Is there a list of ALL the things that need to be re-calibrated / reset after a new battery change?
Thanks in advance.
Old Jun 29, 2020 | 10:33 PM
oilcanhenry's Avatar
Thanks in advance.
Not that I am aware of. Good work finding out about recalibrating your atmo temp sensor, BTW!
Old Jun 30, 2020 | 11:54 AM
Gumby22's Avatar
How long did you have the battery unhooked? Most of the modules are able to retain adaptive memory/calibrations for at least 10-15 minutes with the battery unhooked.
Additionally, the systems that require calibration are capable of “learning on the fly.” Power windows, for example, will re-learn the auto function once the buttons have been used. HVAC will self calibrate if you turn the key on, engine off for about 1 minute. The PCM will re-learn drive ability values automatically, though a few odd “behaviors,” so to speak, may be noticed for the first few drives.
Jaceracer
Aug 25, 2016 12:28 AM
ds1363
Apr 14, 2015 3:53 PM
gray gables
Sep 26, 2012 10:00 PM
Renrax
Apr 24, 2011 6:57 PM
Tieffun
May 22, 2010 6:12 AM
