A/C Blower switch
Old Aug 10, 2022 | 3:24 PM
skinner9's Avatar
Smile A/C Blower switch
I have a 2004 Silverado, 5.3 l. My #4 position on the fan switch keeps failing. Per advice, I replaced the blower motor resistor. After doing so it fixed the #4 position problem. A few days later, the #4 position quits working again. Thinking I may have received a bad resistor I ordered a new one and installed it. Same scenario. Workes for a couple of days then quits working. Am I barking up the wrong tree?
Thanks for any ideas...
Old Aug 11, 2022 | 1:02 PM
chem_man's Avatar
15 Year Member
I would check and make sure that the connector to the resistor pack is not charred/burned creating a poor electrical connection. You remove the plug, reconnect it and #4 works for a short time then stops working. Then you "disturb" the electrical connection, it works for a bit then stops. See where I am going?
Good Luck!
Old Aug 11, 2022 | 7:49 PM
skinner9's Avatar
Thanks...I'll check it out.
skinner9
Jun 8, 2022 9:50 AM
RickR90s
Nov 18, 2016 12:12 PM
Goat-v
Jun 2, 2014 4:28 PM
murphbradyscott
Feb 12, 2012 5:10 AM
ke4wpv
Uplander
Oct 6, 2011 8:14 PM
