Check Engine Light problem
Old Aug 11, 2023 | 12:56 PM
Larrycarol's Avatar
Default Check Engine Light problem
I recently replaced all 4 oxygen sensors on my 2003 Silverado 1500. I did not disconnect the battery before doing this. I have erased all codes, but I keeping DTC's for the oxygen sensors. How can I fix this problem as I am due for a state inspection.
Old Aug 11, 2023 | 4:48 PM
Please post the full DTC's and definitions.
Moving your question to the Silverado section ...
Old Aug 12, 2023 | 12:29 PM
Larrycarol's Avatar
Old Aug 12, 2023 | 12:56 PM
hanky's Avatar
Unfortunately, codes for certain areas do not always mean the parts are malfunctioning or defective. Many time poor connections are involved.
Could you post the codes here?
Old Aug 12, 2023 | 2:47 PM
@Larrycarol
Please avoid duplicate posting. Thank you.
Old Aug 12, 2023 | 10:23 PM
jw11432's Avatar
Definitely need the codes you're getting. Not long ago, I replaced all 4 O2 sensors in my Jeep and it only took a few months for one of them to prematurely fail. So a DOA sensor is possible, but we can only speculate without further information.
Old Aug 17, 2023 | 7:58 PM
carlasdaddy's Avatar
Here are the codes:
P01 41 $10 O2 sensor heater circuit bank 1 sensor 2
P0155$10 O2 sensor heater circuit bank 2 sensor 1
PENDING CODES:
P0135$10
P0141$10
P0155$10
I tried leaving the battery disconnected for 3 days, but that didn't help.
Old Aug 17, 2023 | 11:46 PM
jw11432's Avatar
I found a diagnostic procedure you can follow in my FSM. Hopefully this will help.
Old Sep 24, 2023 | 3:04 PM
Could you send me page 8-34 in Wiring Systems?
Old Oct 2, 2023 | 1:02 PM
Okay, so I got a hold of an Autool Diagnostic Tester. I checked for power and good ground on the harnesses for all 4 sensors.
Here are the results.
Bank 1 Sensor 1 8.8 volts at power and 1.7 ohms at ground
Bank 1 sensor 2 10.8 volts at power and 43 ohms at ground
Bank 2 sensor 1 10.7 volts at power and 44 ohms at ground
Bank 2 sensor 2 11 volts at power and 43 ohms at ground
The only thing strange is the ohms reading for Bank 1 sensor 1.
The only sensor not getting a DTC is Bank 2 sensor 2.
Where do I go from here?
