Chewed Through Wires
Old Jul 19, 2024 | 10:23 AM
hilasmos's Avatar
Default Chewed Through Wires
Can y'all tell me what I need to buy to replace these wires that have been chewed through on my truck? What do they go through? Do I need to buy a complete wiring harness?
Thanks for helping!
Old Jul 19, 2024 | 11:08 AM
Welcome from Florida. You can reconnect them yourself. They are color coded, and you can connect each one-by-one same color to same color. This will take you some time, but it will save the expense of replacing the wire harness.
Old Jul 19, 2024 | 11:56 AM
Gumby22's Avatar
oldchevy is right about the color coding but if you’re going to repair it as-is, you’ll need about 4” of wire per circuit to make up the gap, and I’d recommend soldering instead of crimping.
You can also get a pigtail connector and just splice the engine side of the harness, which is what I would do if this were a customer truck.
Old Jul 19, 2024 | 12:15 PM
hilasmos's Avatar
Thanks, that does help. What are those wires going to? I haven't been able to find a diagram that I can read.
It doesn't look like the harness in that picture has the wires color coded so I know which ones to connect.
Old Jul 19, 2024 | 6:10 PM
Rednucleus's Avatar
I'm curious to know what's not working presently - can you start it?
Old Jul 19, 2024 | 6:33 PM
Gumby22's Avatar
The connector side is for the ignition coils. The harness side runs back to the ECM, fuse block and one will be a ground at the rear of the engine block near the oil pressure sensor.
If you remove the harness wrap you will see the wire colors easier and can match up the cavities on the replacement pigtail using the old connector as a reference.
Ignition coil wiring schematic
Inline harness connector
Connector pinout details
Ronniewoah
Jan 30, 2024 8:51 AM
ducati_848
Mar 5, 2022 9:18 AM
SW Chevy van guy
Aug 31, 2021 3:34 PM
L84sky
Nov 13, 2020 5:54 AM
Tshep
2007 - 2013 (GMT900)
Sep 2, 2019 9:12 PM
