hard start when cold - easy when hot out
winter-spring-fall i have to crank 3 revolutions, key off, then it starts easy. on hot summer days it starts easily without doing so. been like that 10 years.
I realize there are like 7 sensors than can effect "prolonged crank" and i can pull each and bench test against (values i must find separately).
I'm wondering if anyone knows of "a COMMON PROBLEM", so that i don't have to do 7 bench tests
WHAT I'VE DONE: cheap obdii monitor says all temp sensors are within range. i think i already changed coolant temp sensor (done so many i can't remember which car got it when). New fuel pump was req'ed 2 yr ago but didn't help any. head/intake gasket was req'ed 7 yr ago: idles very nice. tune-up done very recently. starter battery replace recently (again, were not related to this problem).
internet: google gives me like 983,982 hits all which say the same old drool. "you need a fuel pump". all of it in-applicable. (i can't find any discussion on hard starting)
Fuel doesn't vaporize particularly well in colder temperatures. Are you confident in the cleanliness of your injectors? They may be squirting more of a stream than a mist, which could potentially explain this.
Are you using the recommended oil for your climate? Thicker oil can hamper cold starts, but I'd be less inclined to suspect this based on your description.
I'm assuming no CEL? How about codes, regardless? I've heard stories of people finding codes stored but there being no CEL to indicate an issue.
Next time it's cold try key on & off 4-5 times before trying to start, then see if it fires up quickly - if so you may need to address a fuel b ack flow valve probably part of the fuel pump. Report back when it gets cold again!!
If it is an injector there may be a little stumble for a bit after start up until the cylinder clears. I would try some injector cleaner.
If my wild guess is correct and it is the fuel rail pressure relief valve then the valve needs to be replaced. Just a guess to be sure.
I replaced fuel pressure unit when I did the headgasket: no change. I replace fuel sending unit just a few years back: no change. Thought I said that in OP.
