Help annoyed
Old Oct 29, 2019 | 7:46 PM
Caledonia Dan's Avatar
Default Help annoyed
Hi all and thanks in advance for any Information. I have a 2003 Silverado 1500hd with the 6.0l About a year ago I started having problems where the torque converter would randomly unlock while on the freeway doing 70-75 for various amounts of time no matter the grade. Also starting about 4 months ago I had the knock sensor P0332 code come up. Last week I finally took the truck in for the transmission and had it rebuilt as it also had a whine in 1st. While it was in also had them do the knock sensors with harness. I got the truck back last week Thursday and to no avail on Saturday the torque converter is still unlocking, shutters from 1st to 2nd and a loud metal clunk shifting to reverse. As of this morning the check engine light came back on this morning throwing the P0332 code again. I dropped it off tonight to have this same place address all these things. Was told he is putting a shift kit in to correct the shuttering. Hes not worried about the clucking telling me its probably in the T case even thou I never had that noise before. And maybe there is a bad ground somewhere causing the code to come back. He said while he was driving with his scan tool attached that there was a random misfire but didn't throw a code and that's causing the converter to unlock. I feel as though I'm being jerked around by this guy. Sorry for the lengthy read but more info the better right? Thanks
Old Oct 30, 2019 | 6:41 PM
oilcanhenry's Avatar
If you think you are being ripped off do a Yelp search for the business. I have a shop for things I cant repair due to time or not having a lift and they are terrific, fast and 10 percent off for having a AAA card.
OBD II code PO332 can be due to:
Defective Knock Sensor
Defective Knock Sensor Circuit or connections
Defective EGR System
Malfunctioning Cooling System
Lean air/fuel ratio
Don't know if that would effect the TC lockup but I suppose its possible since it go to the PTCM.
Old Oct 30, 2019 | 8:22 PM
Lean air/fuel ratio
While I guess that could be possible how then would I have the TC issue long before it ever threw a light?
Old Oct 30, 2019 | 8:54 PM
It happens. The software was perhaps not as well done as it could have been. I've seen MAF sensors that were gone that didn't throw a code.
gafirefighter
Aug 21, 2024 4:48 PM
trainwreck91
Feb 22, 2014 7:38 PM
chdonley
Jun 25, 2013 10:04 AM
hondaman
Jun 18, 2011 3:39 PM
betterdays
Mar 14, 2011 7:07 PM
