Instrument cluster
Old Dec 22, 2022 | 8:11 AM
gary.rouse@juno.com's Avatar
Default Instrument cluster
After vehicle has been setting and turn on the key the gauges don't read correctly. They all read low. Once truck is warmed up and shut off and restarted, the gauges read correctly. Any ideas?
Old Dec 28, 2022 | 1:47 AM
dcddrawhorn@gmail.com's Avatar
Possible pigtail issue, or body control module maybe, just a wild guess.
Old Dec 28, 2022 | 11:53 PM
2001 chevy silverado's Avatar
2001 guages are always flakey, IDK. after an overhaul i would expect it to do that 1st time and ignore it?
Always insure battery is good first. Insure there are no parasitic leaks.
* insure key on/off is doing it's work (work it carefully to insure it makes contact it should)
* fuses are for pulling. isolate off un-necessary things by pulling fuses, see if that helps.
* the wiring box near the gas pedal may have poor grounding. it is wired quickly by hand.
silverstreak
Jan 7, 2024 11:26 PM
Luke C
Jul 2, 2020 10:55 AM
Racer04
Feb 28, 2019 9:27 AM
TM8
Jan 3, 2018 2:34 PM
jpskperry
Mar 1, 2013 1:43 PM
