Knock sensor issue
Old Jan 31, 2023 | 10:07 PM
cowdude's Avatar
Default Knock sensor issue
My 2006 silverado classic has 194k miles and I have started getting a knock sensor code after reaching 70mph then slowing down to exit the interstate. I have ran a test and drove 60mph for 5 days and no code. the next week I ran 60 one day and 70 the next and at 70 slowing down it pops the code. I get fuel at the same station all the time and have had no issues. I wonder if it is something else. I had a cold air system on it and took that off to see if it was the problem but it wasn't. Any advice will help. I only have weekends to do any checking. I have no performance issues at all
Thanks in advance
Old Feb 1, 2023 | 10:41 PM
chem_man's Avatar
15 Year Member
I would check the EGR valve and tubing between the EGR valve and the engine to make sure they are not filled with carbon deposits. While the EGR valve might be opening and closing, it might not be passing exhaust gasses as readily as it should.
Good Luck!
Old Feb 1, 2023 | 11:11 PM
cowdude's Avatar
I didn't think of that. Thanks for the help, I'll check that out this weekend.
Old Feb 2, 2023 | 9:52 PM
chem_man's Avatar
15 Year Member
Good Luck!
rbreaux72
Aug 8, 2020 8:42 AM
Dgifford
Jan 23, 2018 12:33 PM
trainwreck91
Feb 22, 2014 7:38 PM
betterdays
Mar 14, 2011 7:07 PM
Bertha
Dec 2, 2008 12:38 PM
