At my wits end
Old Mar 3, 2020 | 9:42 AM
Roby4life's Avatar
Post At my wits end
2006 Chevy Silverado 4.3L 2 Wheel Drive - Current Mileage Approx 99,000
Just bought the truck very clean stored in a garage never driven in the winter. A week after I bought it, it developed a hard starting problem "currently winter temps around 20 degrees" which lead to a no start issue. if the key was cycled 3-4 time prior to starting it would start fine. led me to believe that is was a fuel delivery issue. ended replacing the fuel pump and all of the fuel lines with factory replacement parts. Also did a complete tune up with A/C Delco Parts. Truck was starting fine for a few days and now we are back to the same thing again. I do not have any issues with wire corrosion everything is very clean I had already checked for that while the tank was out. Keeping in mind also that this vehicle was purchased by the prior owner with 62,000 miles on it in 2010 so they put 37,000 miles on it in the ten years that they owned it. I am at a lose. when running the truck runs like it just came off of the show room floor.
Old Mar 3, 2020 | 9:44 AM
Irish_alley's Avatar
I'm here for the party
have you checked the fuel pressure regulator?
Old Mar 3, 2020 | 10:22 AM
Roby4life's Avatar
That was my next thought or I have a fuel injector leaking
Old Mar 3, 2020 | 10:52 AM
Did you replace the fuel pump with a cheap aftermarket pump or did you get a Delco or Delphi pump? I have heard many times that the cheaper pumps fail shortly after installation.
Old Mar 3, 2020 | 10:54 AM
Roby4life's Avatar
I used one made by Car Quest never had any issues with that brand
Old Mar 3, 2020 | 2:55 PM
Do a fuel pressure check when first trying to start it when it is cold.
Old Mar 3, 2020 | 4:35 PM
kevinkpk's Avatar
I'd look at where you are buying gas, and perhaps add a can of heet to the tank.
skram
Mar 23, 2019 9:35 AM
2000SltGuy8605
Jun 11, 2017 1:13 PM
tmaxfield
May 29, 2017 8:07 PM
Jwallen84
Nov 23, 2013 12:07 PM
Garon
Nov 21, 2011 8:18 PM
