need a bigger alternator
Old Mar 26, 2024 | 2:00 PM
zty116's Avatar
Default need a bigger alternator
I have a decent sound system in my truck, when at a stop the lights dim when the bass hits from a song. I am looking for a bigger alternator, in my search I really only find overwound ones. If anyone has any leads that would be great. Thanks. ( I know I will most likely need a different belt)
Old Mar 26, 2024 | 2:03 PM
Welcome from Florida. What is the amp rating on the alternator that you have now? You can also put a smaller pulley on your alternator and that will make it spin a little faster so at idle it puts out more.
Old Mar 26, 2024 | 4:37 PM
zty116's Avatar
I have the stock one which I believe is a one twenty
Old Mar 26, 2024 | 4:40 PM
Rednucleus's Avatar
Welcome from WA - my dear departed mother would tell you to turn down that darn music!!!
When sitting at idle, what's the volt reading at the battery using a multimeter?
Old Mar 26, 2024 | 10:48 PM
chem_man's Avatar
15 Year Member
How old is your battery and have you had it load tested to make sure it is not going bad?
Old Mar 27, 2024 | 12:16 PM
zty116's Avatar
It's not my battery. I am looking for a bigger alternator not an overwound one.
Old Mar 27, 2024 | 12:17 PM
zty116's Avatar
if I remember it was at like 10 something, not going to kill the truck but not helping the situation out any.
Old Mar 27, 2024 | 12:57 PM
Rednucleus's Avatar
So that shows you are not getting a charge at idle. Does it jump up to 13.5v or greater at 1000rpm? What's your battery voltage motor off after sitting overnite?
If battery is not new have it tested; could be part of the problem
Old Mar 27, 2024 | 1:27 PM
zty116's Avatar
if no big bass is playing it fine as soon as bass its voltage drops, no problem charging if no major bass is playing. But still i have no problems with it keeping a charge, want/need bigger alternator for the longevity of my battey/trucks electrical system life.
Old Mar 27, 2024 | 1:44 PM
what is your idle battery voltage with the stereo off?
Chopperdoc
Mar 27, 2024 3:10 PM
MTopper
Dec 25, 2015 12:34 AM
mikethenic
Aug 6, 2014 8:44 PM
rocknrollben
Feb 10, 2010 4:48 PM
jcbst12
Nov 14, 2008 6:05 PM
