No idea what happened
Old Mar 7, 2019 | 7:40 PM
Jrock1982's Avatar
Default No idea what happened
So im on my way home from work on the interstate and had to come to a stop quickly. After doing so my truck started to run extremely bad and it wouldn't shift gears. I'm thinking my abs engaged maybe and that's whats causing it but im not sure and will welcome any other ideas.
Old Mar 7, 2019 | 8:49 PM
Doug D's Avatar
A faulty ABS would trigger the ABS light on the dash. Might help if you could post more information about your vehicle - year, engine, etc. Is the check engine light on? Did you check for fault codes? That would be a good place to start. It may be just coincidence it began to run bad after a panic stop.
Old Mar 7, 2019 | 9:00 PM
Jrock1982's Avatar
Sorry its a 2001 Silverado 5.3 liter. Yes the check engine light is on has been since I bought it along with the abs light and the parking brake light even though ive pulled the lever numerous times. The reason I was thinking abs engaged is because it did start immediately after I had to suddenly stop.
Old Mar 8, 2019 | 6:29 AM
Doug D's Avatar
Well , if the ABS/Brake light is on it's telling you there is an issue with the ABS and the hydraulic brake system. Could be as simple as the fluid is low. For the ABS you'll need to have the module scanned for fault codes. May have a bad sensor. The ABS will not engage if the ABS light is on.
Check Engine Light - first place to start is to have the PCM scanned for codes and see what it is telling you. Then diagnose from there.
Personally, I don't like driving around with the ABS or Brake light on.
Old Mar 19, 2019 | 3:20 PM
Jrock1982's Avatar
Default Silverado shifting problems
Hi everyone was needing a little help. I have a 2001 Silverado 1500 2wd 5.3l. My truck is not wanting to shift out of second. I've replaced both shift solenoids and also just replaced the trans shift sensor and it is still not shifting. I have very limited knowlege of vehicles and all the research I did said it was one of those two things and in my case it is not so any ideas of what it could be or what I should check will be GREATLY appreciated. Hope you all have a wonderful day thanks.
Old Mar 24, 2019 | 8:47 PM
oilcanhenry's Avatar
Thi Tech Bulletin might help you out, Jrock1982:
TECHNICAL
Bulletin No.: 09-07-30-004I
Date: May 10, 2012
Subject: Slips in Reverse or Third, Delayed Reverse or Drive Engagement, DTC P0776, P2715, P2723, Harsh 2-3 Shifts (Inspect 1-2-3-4 / 3-5-R Housing and Pump Seal Rings)
Models:
2006-2009 Cadillac STS-V, XLR, XLR-V
2007-2008 Cadillac Escalade, Escalade ESV, Escalade EXT, XLR
2006-2009 Chevrolet Corvette
2007-2008 Chevrolet Silverado
2008 Chevrolet Suburban
2007-2008 GMC Sierra, Sierra Denali, Yukon Denali, Yukon XL Denali
2008 GMC Yukon XL
2008-2009 HUMMER H2
2008-2009 Pontiac G8
Equipped with 6L80 or 6L90 Automatic Transmission (RPOs MYC, MYD)
Supercede:
This bulletin is being revised to add the last Important statement under 2006-2009 Vehicles section and add the transmission filler tube to the Parts Information. Please discard Corporate Bulletin Number 09-07-30-004H (Section 07 - Transmission/Transaxle).
Condition
Some customers may comment on any of the following conditions:
- Slip when Reverse is selected or no reverse.
- Delayed engagement into reverse.
- MIL illuminated. DTCs P0776, P2715 or P2723 are found as an active or a history code in the TCM.
- Harsh shifts from second to third.
- Harsh shifts from fourth to fifth or slips in fifth.
- Slips on acceleration when passing.
2006-2008 Vehicles
Cause
This condition may be caused by a cracked 1-2-3-4 / 3-5-R clutch housing
Old May 18, 2019 | 4:40 PM
Jrock1982's Avatar
Default Shift problems
So my truck won't shift out of second for nothing. I've even tried riding in 3 gear to see and does the same. I've replaced both shift solenoid and the shift relay. My question is is there anything else I should check before taking it to a tranny shop and having it replaced?
Old May 27, 2019 | 6:19 PM
Jrock1982's Avatar
TECHNICAL
Date: May 10, 2012
Models:
2008 GMC Yukon XL
2008-2009 HUMMER H2
Supercede:
Condition
2006-2008 Vehicles
Cause
hey man so I read through this (thank you btw) but non of these issues are my problem. It won't shift out of first. I changed both shift solenoid and shift sensor relay but still won't shift out of 1st. Reverse is working fine and before this started I shifted through gears fine no grinding or anything
