Oil on the spark plugs
Old Mar 12, 2020 | 8:31 PM
2003SilveradoBoss's Avatar
Default Oil on the spark plugs
Hello there, my truck has been running difficult for a few days and shes my daily driver, it threw engine misfire codes and fuel trim lean bank 1, I work on vehicles as a hobby and a passion but I cant figure out what really is wrong with it, the oil is on the threads and inside the engine, it blows out white smoke.....kinda know theres an oil leak somewhere but I dont know what it could be from, need a little help, thanks
Old Mar 13, 2020 | 3:56 AM
oil in the combustion chamber can come from a few places ...
blown head gasket
valve guide
piston rings
Since you're having a misfires, my money is on the gasket. Do a compression test.
Old Mar 13, 2020 | 10:46 AM
blown head gasket
valve guide
piston rings
I'll check it out, thanks bud
also, could I keep driving my truck, or will I cause irreversible damage
Old Mar 13, 2020 | 6:03 PM
Thanks for the but my engine seized this afternoon....so I'll have to get a new one
Old Mar 13, 2020 | 10:29 PM
possibly head gasket blew right out and pistons hydro-locked. White smoke was probably coolant (steam). Oil smoke tends to be more blue.
You might be able to save the engine with a top end rebuild. $200 for gasket kit. $200+ for surface machining.
Old Mar 13, 2020 | 10:41 PM
oilcanhenry's Avatar
True but he has got to make sure the engine oil has no coolant in it else his bearings are toast.
Old Mar 14, 2020 | 12:28 AM
Oh well. It's a 17 yr old vehicle. Possibly high mileage. If I wasn't particularly attached to the engine, I would just flush it really well and then drive it until it quit.
silverado2001
10
Dec 16, 2020 3:45 AM
wbywmu
1988 - 1998 (GMT400)
Oct 26, 2017 6:26 PM
dboard7
Mar 14, 2013 7:40 PM
LS Silverado
Sep 20, 2012 4:00 PM
peedeefish
Sonic (Aveo)
Jan 16, 2010 10:31 PM
