Rear Differential Trying to Lock Up 58,000 miles
Old Jan 22, 2023 | 10:07 AM
arnie henderson's Avatar
Exclamation Rear Differential Trying to Lock Up 58,000 miles
2000 Silverado 2500 4x4 373 rearend. Only 58,000 miles. Fluid changed at 42,000. Used GM recommended fluid. No abuse or too heavy pulling. Have not pulled the cover yet. Hard to believe it is failing at this milage. Anybody else have this problem or any ideas about the problem.
Old Jan 22, 2023 | 10:17 AM
Rednucleus's Avatar
Welcome to Chevy Arnie.
Please decribe the details of what your truck is doing. Lots of help available here when we get a detailed story. I just had a front wheel hub assembly fail on our '20 Tahoe under 50k miles. I agree that's low miles for a diff failure.
Old Feb 7, 2023 | 5:42 PM
Fastmann40's Avatar
Exclamation
Originally Posted by arnie henderson
2000 Silverado 2500 4x4 373 rear-end. Only 58,000 miles. Fluid changed at 42,000. Used GM recommended fluid. No abuse or too heavy pulling. Have not pulled the cover yet. Hard to believe it is failing at this mileage. Anybody else have this problem or any ideas about the problem.
Any updates on this one?
Old Feb 7, 2023 | 5:56 PM
hanky's Avatar
Your description does not provide enough info to offer any suggestion.
At this time we don't know if it gear related. brake application related Or anything else.
So as you can see we need to be as specific with the description as possible Thanks.
Old Feb 7, 2023 | 6:57 PM
Fastmann40's Avatar
This is the quote I was wondering about. I understand your notes. Thanks
Old Feb 19, 2023 | 3:14 PM
no way to know without inspection. this is not a common issue. Usually its abuse or water filled fluid or bad rebuild that is the cause.
2012Chevy
May 29, 2017 1:19 AM
Stimpy911
Oct 13, 2011 2:01 AM
DGorris
Oct 6, 2011 11:20 AM
Caper001
Oct 5, 2011 8:34 PM
tbb2
Aug 13, 2011 7:06 PM
