Rebuilt engine starts with high RPM and then shuts down
Old Dec 8, 2023 | 3:11 PM
gregdw's Avatar
Default Rebuilt engine starts with high RPM and then shuts down
I have an LM7 engine from a 2001 Silverado in my 300zx. After trying to build oil pressure by cranking it for 5-10 seconds on two different days with the coil packs disconnected, I observed no pressure on the cluster gauge. I then started the engine with everything connected, following advice that it wouldn't harm a well-lubricated rebuilt engine. The engine revved to 4K RPM and shut off, and the cluster gauge didn't show oil pressure. I checked and confirmed all vacuum lines were connected. Suspecting an issue with the TPS, I disconnected it. Today, I ran the engine again with an oil pressure mechanical gauge attached, and it showed 40-50 PSI. However, the engine still revved to 4K RPM and then shut off. Each time I start it, it runs for 2 seconds ramping up to 4K RPM, oil pressure shoots to 40-50 PSI, and then turns off.
I am using a 2001 GM ECM that has been tuned to remove VATs/Security for the swap. I am completely stumped on what could be causing the RPM to shoot up and then to power down. Does not seem consistent with a vacuum leak unless the ECM has some form of cut off or safety procedure that I'm not aware of (very possible).
Any help or ideas would be greatly appreciated.
john432
Sep 9, 2015 6:46 AM
kfnpemai
May 9, 2015 11:27 AM
trx680
Aug 2, 2014 8:39 AM
hammergirl08
Jul 18, 2014 4:48 PM
kwoods
Dec 10, 2008 11:04 PM
