Transfer case vibrations
Old Jul 1, 2020 | 1:36 PM
mleonard53212's Avatar
Default Transfer case vibrations
2006 Silverado WT 2500 HD 125k miles.
Shift lever for the 4x4 activation vibrates at 35mph. Also, unable to shift to 4 low or neutral.
Dealer has done work to transfer case in the recent past (multiple leakes/seals replaced) but states the vibration is coming from a bad sensor, wanting to charge me $330. Is this legit?
Im assuming they do not want to do the work for free admitting they messed up. I just do not have any proof to argue my point.
In order for the seals to be replaced (August 2019/June 2020), drive shaft needed to be removed.
Old Jul 1, 2020 | 2:20 PM
kevinkpk's Avatar
Sounds like an out of balance drive shaft..
Old Jul 1, 2020 | 6:03 PM
Gumby22's Avatar
That’s a complete grade A garbage diagnosis. Faulty sensors can cause hard shifts and bucking/jerking, but not vibrations, and since it’s a manual shift t-case, that rules out an encoder motor issue.
The driveshaft could be out of balance but that wouldn’t prevent shifting.
Go to another shop and get a second opinion - don’t tell them you had a dealer work on it - just see what they say. If they diagnose a problem internal to the t-case, take it back to the dealer in writing.
Old Jul 1, 2020 | 6:43 PM
kevinkpk's Avatar
Are you trying to shift into 4wd at 35 mph?
Old Jul 2, 2020 | 11:36 AM
No. I was sitting in my driveway not moving. That was just issue #3.
I felt the 'sensor' excuse was BS from the get-go. I just am searching for info.
Howard Henderson
Feb 10, 2019 6:48 PM
Hoooozzz
2007 - 2013 (GMT900)
Aug 28, 2017 5:38 PM
Electricman3
May 8, 2011 6:18 PM
vanddelor
Mar 23, 2011 10:22 PM
tazman6789
May 15, 2008 7:08 PM
