what are the max miles on 4l60e transmission before failure with regular service
Old Mar 10, 2016 | 10:45 PM
advcomps's Avatar
Question what are the max miles on 4l60e transmission before failure with regular service
I am looking at buying a 2000 Silverado LT with the Z71 package and 5.3 engine. It has 218,000 miles on the original engine and transmission. asking price is $4500
It is a one owner truck and and I know the guy well enough to believe him when he says that it has been service regularly and not abused.
What is the chance that the 4l60e can last 300k miles or more?
thanks in advance, Cal
Old Mar 10, 2016 | 11:12 PM
Rednucleus's Avatar
Can you show us service intervals on the transmission?
My 93 made it to almost 200k when it died. Has a reman now.
Old Mar 10, 2016 | 11:25 PM
its not impossible. I have seen them go that far. 200 plus is generally near the end of life. it may go to 300 it may fail tomorrow. It will have some wear on it.
When you buy something that old all you can do is inspect the fluid, test drive and check for dtc and I/M monitors. If that all is ok and the body is rust free, make an offer. Its not worth 4500 imo
Old Mar 11, 2016 | 2:20 PM
afastchief's Avatar
My 2004 suburban made it to 225 and lost 2nd gear. Had that fixed but not completely rebuilt. It made it to 260 and lost 3rd and transfer case was making a scraping noise. I pulled both out myself and took it to a renowned 30+ year local tranny guy. Rebuilt both units and updated with latest parts. $1500 for tranny and new torque converter, $700 for transfer case. I replaced the radiator and external tranny cooler. I got both parts from NAPA. Should have it back on the road tonight.
Old Mar 12, 2016 | 10:59 AM
advcomps's Avatar
Default what are dtc and I/M monitors?
There is no check engine light and the ETC codes are clear.
The fluid is clean and does not smell burnt.
Old Mar 12, 2016 | 5:24 PM
have all the I/m monitors run and passed? this ensures the seller didn't clear the dtc with a scan tool. if there are incomplete monitors, he has cleared dtc to hide a problem
Old Mar 22, 2016 | 5:53 PM
marble765's Avatar
I have a 2005 Z71 with 5.3l and mine started slipping BAD at 220360. The tabs in the drum were worn, half of the clutches were gone and started warping. I am the second owner
Old Mar 22, 2016 | 6:19 PM
the 4L60E in my 97 Tahoe lasted for a whole 11k mile before it was rebuilt under warranty....
Old Apr 25, 2016 | 7:25 PM
just4gman's Avatar
2003 Z71 with 5.3l and 275,000 on it. I neglected the trans maintenance, it just started slipping yesterday, I believe it would still be going strong if I had not got lazy and didn't change the filter and fluid 100,000 miles ago....
Old Apr 25, 2016 | 11:33 PM
hicksvilleshick's Avatar
I've seen them knock on 300k with religious maintenance.
I still haven't given mine a real hard look yet, but it shifts as expected and a jiffy lube guy had it before me so I have to believe it's been at least flushed.
If it goes I'll likely go for one out of a bone yard and have one built.
